moynesyt5
Message 1 of 9
Wifi Extenders
Hi All
I have just had Virgin Broadband installed today and contrary to what the installing guys sais, my broadband is weak in parts of the house, very weak.
So I purchased a BT wifi range extender but I could not make that connect to the router. So I went to exchange that for a Netgear AC1200 and again I can't get it to connect. Is there a certain make to purchase or what am I doing wrong?
I'm not best pleased that the location of the router doesn't cover the house when the engineers said it would! I didn't expect to have to buy a wifi ranger extender today.....that doesn't work!
Not impressed so far to be honest. I get 100meg speed next to the router but move to another room and that is down to 20meg and then near non excitant in another room.
Dave
  • 2.76K
  • 224
  • 843
Dave_cq
Trouble shooter
Message 2 of 9
Re: Wifi Extenders
Hi Dave,
Range extenders are really a waste of time.  What you need are Powerline Adaptors with Wi-Fi which use your mains wiring to convey the signal to another location and create a new access point.  I've used Devolo and found them to be excellent ... https://www.amazon.co.uk/Devolo-Powerline-Starter-Adapter-Extender/dp/B00OZDO8RE/ref=sr_1_1?ie=UTF8&...
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 9.36K
  • 801
  • 1.96K
Message 3 of 9
Re: Wifi Extenders
How are you trying to set up the range extender?
Are you using WPS? This would be the easiest method. Instructions here
Can your devices see the xxxx_EXT network?
I can agree with Dave regarding the effectiveness of wireless repeaters as they need a good signal to relay and they will halve the speed due to the half duplex nature of wireless. However, with careful placement they can offer some benefit.
  • 3.01K
  • 383
  • 952
Message 4 of 9
Re: Wifi Extenders
Ditto to what @Dave_cq said and here is a link to a review of powerline adapters that might help:
http://www.pcadvisor.co.uk/test-centre/network-wifi/20-best-powerline-adapters-2016-2017-uk-3490638/
Also have a look at the advice on getting better wireless posted on the forum HEREHERE these posts have tips and suggestions that can might improve things without buying additional kit.
______________________
Scott
moynesyt5
Message 5 of 9
Re: Wifi Extenders
Hi Dave
Thanks for the reply, that seems the best way forward. I have got the wifi range extender working now, as I had to connect itto my laptop and then register etc, but as you say it is still poor considering what you are paying for from Virgin!
I will try the powerline adapters. Do they interfere with the cables at all? Or do they work fine?
Thanks Dave
  • 2.76K
  • 224
  • 843
Dave_cq
Trouble shooter
Message 6 of 9
Re: Wifi Extenders
moynesyt5 wrote:
Hi Dave
Thanks Dave
Never experienced any interference problems.  So long as your house wiring is sound they should work a treat and the good thing about them is you can always add extra slave units in other rooms should that prove necessary.
Electron
  • 20.77K
  • 557
  • 3.22K
Sephiroth
Message 7 of 9
Re: Wifi Extenders
Just to add my tuppence worth, if I ,ay. WiFi Range Extenders are indeed a waste of time as they depend on your house being WiFi friendly, which it appears not to be plus they work in a half-duplex (relay) mode.
The VM techs know nothing about your walls, floors and so on and thus cannot give you any indication as to how WiFi might perform in your house. Added to that, it depends where in your room the Hub is placed.
Powerline adapters are the way to go; I have them in two houses and am very satisfied.
Keep us posted.
moynesyt5
Message 8 of 9
Re: Wifi Extenders
Hi All
I did purchase some Devolo power line adaptors and they are working great with excellent speed and covering the whole house.
Thanks for all you help and advice which was exactly what I needed.
Cheers
  • 20.77K
  • 557
  • 3.22K
Sephiroth
Message 9 of 9
Re: Wifi Extenders
Glad you're sorted.
A few years ago, I hung the SH from a lamp in the middle of the room to see if it propagated better through the house. It did! Of course nobody would be coax wired like that and not get clobbered by the wife or husband or partner or whatever PC word I should be using.
