  • 38
nortonphil
Wifi Dropping
My Wifi has been dropping in and out for the last couple of weeks.
Superhub 2.
It's on... fast, then slow, then completely off, then back on but slow.
Nothing has changed. Wired connection still super fast at 220. Just wifi is not as advertised.
Please assist.
  • 22.22K
  • 845
  • 3.23K
Re: Wifi Dropping
wifi connections can be very unstable due to the the channels being shared with lots of people/devices. You can try changing the wireless channel on the SH.
If the wired connection is good and working its not the VM connection and will be limited to the wifi
  • 38
nortonphil
Re: Wifi Dropping
Happens on all channels (I've got a couple of wifi analysers showing best and worst channels to use).
I suspect after 2 years the components are beginning to "fail" in the SH2.
