  • 7
danieloverton
WiFi light continuously flashing on SH3
For some reason the wifi light on my SH3 has been flashing continuously for the past 3 days. No problems with connection or speed and the light stays flashing even after a reboot. Any ideas what the reason might be?
It's flashing the same as if you press the WPS button, except it's continuous. Seen some old posts saying it was a bug in the original firmware, but I have the latest version apparently.
  • 4.31K
  • 91
  • 280
Moderator
Moderator
Re: WiFi light continuously flashing on SH3
Hi danieloverton
Thanks for posting. I've seen this asked a few times recently. It appears to happen on some Hub 3's  but doesn't affect the connection. I'll see if can chase up an update on what's being done with this.
Speak soon Smiley Happy
Ty
  • 7
danieloverton
That would be great because its annoying as anything flashing away in the corner.
