  • 5
jayl6191
WiFi connection problems
Anybody else having to reset there hub to reconnect there wifi devices ?
Normally every morning I have to do it, then some days up to 6 times or more!
Rang them up loads of times they always say we will change settings? But always still the same problem. It's a black super hub around 12 months old. Is it worth asking for a new one as this is getting to be a pain.
  • 11.04K
  • 326
  • 672
Re: WiFi connection problems
Hello jayl6191,
Thanks for posting and welcome to the community Smiley Very Happy
Sorry to hear about the trouble you're having with your wireless connection, I know this is frustrating.
You mentioned that when you call the operator changes some settings, I suspect they're changing your wireless channel. This will often help if you're experiencing wireless interference. You might also find that using a wireless network scanner will help as it will show you what channels the other routers in your area are using.
Please let us know if this helps,
Take care.
Heather_J
