AlbertPS74
WiFi Super Hub 2
I have a Superhub 2 connected to a LAN via a Netgear Router and Netgear 24 o/p switch with multiple PCs, printers etc. all on fixed IP addresses. (only one o/p active on the hub so assume it is in Modem mode.)
Both WiFi freqs. on Hub are turned off.
Can I turn both these back on (to use with a laptop and Smart TV) and still maintain the LAN as is.
Here's hoping
Pete S.
  • 12.5K
  • 353
  • 1.46K
Re: WiFi Super Hub 2
Hi Pete S,
I believe you can do this though you'll need to disable DHCP on the Netgear router and change it's LAN IP so it doesn't conflict with the Hub's LAN.
I don't have a Hub myself though so for more information on this I'd like to invite the Community to post advice.
All the best,
Jen
AlbertPS74
Hi Jen
Many thanks for your reply.
I contacted the Virgin Media Help line and a man in the Call Centre in India set it all up for me over the net.
I now have WiFi and the LAN is unchanged, I can now use the Smart TV and Laptop independant of any cables connected to the LAN.
AlbertPS
