Warrenden
WiFi Help
I have built a garden office and the WiFi signal from the router is to far away. I have taken a cat 6 network cable from the router to the building, but I would like a WiFi signal is there any device I could attach to the cable to give me WiFi
Many thanks
PhilH
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Re: WiFi Help
Yes, pretty much any old router with wifi capability can be added to give you a wifi hotspot
just connect the Ethernet cable to it, give it a different ip address to the hub and disable dchp on the router.
... of course if you want  better quality wifi then  go for a better router.
you could get a proper wifi access point, but they tend to be more expensive.
Warrenden
Re: WiFi Help
Hi stevedh2
Thanks for the info I will have a look on eBay for a router.
Warrenden
