Jim80
Why does my super hub 2 keep dropping wifi signal, all lights are blue very unhappy ๐Ÿ˜’
Blooming wifi keeps failing all lights are blue very unhappy ๐Ÿ˜’
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Re: Why does my super hub 2 keep dropping wifi signal, all lights are blue very unhappy ๐Ÿ˜’
Hi Jim80,
Thanks for letting us know about your Super Hub 2 dropping connection, I apologise for any inconvenience caused.
I have tested the connection from this side and everything looks great! No errors or time outs inside the hubs logs and all of the power levels are within the preferred ranges.
Are you still having these issues? If so, please respond to me here with a recent copy of your Hubs logs for me to compare with the data we have here. You can find these by opening your internet browser and typing 192.168.0.1 into the address bar, before logging in, it will say 'Router Status' click there and all the information needed is inside.
Take care,
Adam.
  • 16
s9750
Adam L, can I ask for your assistance as well. I have a similar problem. All the lights are on and my network is described as public and no internet access. I need to reboot the hub at least daily. I have tried to add the log you described back to 20th. Hope it is correct, or is it better copying to a word document.
Thanks..
First Time Last Time Priority Error Number Description
27/12/2016 14:06:42 GMT 27/12/2016 14:06:42 GMT Error (4) 68010302 DHCP WAN IP - removed
27/12/2016 14:05:40 GMT 27/12/2016 14:05:40 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
24/12/2016 15:24:01 GMT 24/12/2016 15:24:01 GMT Error (4) 68010302 DHCP WAN IP - removed
24/12/2016 15:23:01 GMT 24/12/2016 15:23:01 GMT Error (4) 68000407 TOD established
24/12/2016 13:17:14 GMT 24/12/2016 13:17:14 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
20/12/2016 21:43:55 GMT 20/12/2016 21:43:55 GMT Error (4) 68010302 DHCP WAN IP - removed
20/12/2016 21:42:54 GMT 20/12/2016 21:42:54 GMT Error (4) 68000407 TOD established
20/12/2016 21:11:29 GMT 20/12/2016 21:11:29 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
20/12/2016 17:46:32 GMT 20/12/2016 17:46:32 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
20/12/2016 10:56:41 GMT 20/12/2016 10:56:41 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 3.88K
  • 120
  • 203
Hi s9750,
Thanks for the post! I am sorry to hear about your issues with your broadband being slow and dropping. I apologise for any inconvenience caused.
I have tested your connection and everything looks great no errors or time outs inside the Hubs logs and all of your power levels are within the preferred ranges.
Are you still having these issues? If so, what lights are on the Hub?
Please respond with another copy of your Hubs logs and I'll compare this with the data we have here.
Adam.
