  • 55
  • 9
oldgit
Dialled in
Whatsapp not connecting
Whatsapp can't connect to wi-fi in my house.
The app connects to other VM routers elsewhere and can connect to other wi-fi .
This applies to both my wife and me.
Any solutions are helpful.
  • 10.64K
  • 312
  • 654
Re: Whatsapp not connecting
Hello oldgit,
Sorry to hear about your problems with Whatsapp, I can't say I've come across this before.
Are other people able to access Whatsapp via your Wi-Fi connection? Do you get any error message or does it just get stuck 'connecting'?
Hope to hear back from you soon so we can continue to investigate.
Speak with you again soon,
Take care.
Heather_J
  • 55
  • 9
oldgit
Dialled in
Hi Heather,
I can connect on my daughters wi-fi,also VM and any other wi fi connection but it just doesn't work on my home connection.My wife also has the same problem with her phone. Perhaps my settings need adjusted
First Time Last Time Priority Error Number Description
17/12/2016 09:27:10 GMT 17/12/2016 09:27:10 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
17/12/2016 05:31:19 GMT 17/12/2016 05:31:19 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
16/12/2016 21:39:36 GMT 16/12/2016 21:39:36 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
16/12/2016 05:56:08 GMT 16/12/2016 05:56:08 GMT Error (4) 68010100 DHCP RENEW sent - No response for IPv4
14/12/2016 14:58:33 GMT 14/12/2016 14:58:33 GMT Warning (5) 66050310 Auth Success - Web login successful.
12/12/2016 08:27:45 GMT 12/12/2016 08:27:45 GMT Warning (5) 66050310 Auth Success - Web login successful.
11/12/2016 10:38:31 GMT 11/12/2016 10:38:31 GMT Error (4) 68010302 DHCP WAN IP - *******
11/12/2016 10:37:38 GMT 11/12/2016 10:37:38 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
08/12/2016 13:02:37 GMT 08/12/2016 13:02:37 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
08/12/2016 12:08:25 GMT 08/12/2016 12:08:25 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/12/2016 12:08:07 GMT 08/12/2016 12:08:07 GMT Warning (5) 66050300 Auth Fail - Web login failed.
08/12/2016 12:03:07 GMT 08/12/2016 12:03:07 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/12/2016 12:01:27 GMT 08/12/2016 12:01:27 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/12/2016 12:01:18 GMT 08/12/2016 12:01:18 GMT Warning (5) 90000200 CSRF Detect - Expired Content Submitted ; LAN Interface
08/12/2016 11:58:10 GMT 08/12/2016 11:58:10 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/12/2016 11:52:43 GMT 08/12/2016 11:52:43 GMT Warning (5) 66050310 Auth Success - Web login successful.
08/12/2016 11:52:13 GMT 08/12/2016 11:52:13 GMT Warning (5) 66050300 Auth Fail - Web login failed.
08/12/2016 11:51:42 GMT 08/12/2016 11:51:42 GMT Warning (5) 66050300 Auth Fail - Web login failed.
08/12/2016 11:51:08 GMT 08/12/2016 11:51:08 GMT Warning (5) 66050300 Auth Fail - Web login failed
Upstream   US-1 US-2 US-3 US-4
Channel Type N/A N/A 2.0 2.0
Channel ID N/A N/A 15 16
Frequency (Hz) N/A N/A 32600000 25800000
Ranging Status Other Other Success Success
Modulation N/A N/A 16QAM 16QAM
Symbol Rate (Sym/sec) N/A N/A 5120000 5120000
Mini-Slot Size N/A N/A 4 4
Power Level (dBmV) N/A N/A 45.75 45.50
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 299000000 267000000 275000000 283000000 291000000 307000000 315000000 323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 13 9 10 11 12 14 15 16
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) -3.67 -3.72 -3.60 -3.64 -3.79 -3.94 -4.02 -4.07
RxMER (dB) 36.39 35.97 36.17 36.17 36.61 36.61 36.39 36.17
Pre RS Errors 21926 28476 2104 2584 1605 1686 953 1079
Post RS Errors 772 678 619 663 1371 1429 678 764
[MOD EDIT: Personal and private information has been removed from this post. Please do not post your WAN IP in your public posts. Please review the Forum Guidelines]
  • 55
  • 9
oldgit
Dialled in
http://www.thinkbroadband.com/ping/share/96a15a6216255fb5be98170cd0dc606a-20-12-2016.html
  • 10.64K
  • 312
  • 654
Hey oldgit,
Thanks for the update Smiley Happy
Sorry to hear this is still on-going. You could try changing the operating wireless channel of your router and see if this helps at all. This help article will show you how to sign into your Hub and make the changes.
Could you please have a go and let us know if it helps.
Take care,
Heather_J
  • 55
  • 9
oldgit
Dialled in
Changed channel.No difference.
