  • 48
  • 7
Jack_C
Dialled in
Message 1 of 8
What's the best way to record and document intermittent wireless connectivity issues? [LE5]
My family and I are experiencing intermittent wireless connectivity issues (worse at night) and would like to bring this to somebody's attention. I don't however want to bring it to anyone's attention without the proper supporting evidence.
How can I achieve this?
Thank you.
Kind regards,
Jack
Helpful Answers
  • 3.01K
  • 383
  • 952
Message 8 of 8
Re: What's the best way to record and document intermittent wireless connectivity issues? [LE5]
OK that looks better, you now have two upstream channels with status "Success" which is how it should be.
With regard to the wireless, the Auto channel setting is supposed to pick the best channel whenever the hub is restarted.  In my experience it doesn't always get it right.  As @pyrotenax has suggested a wireless analyzer app might be worth a try to see what your wireless environment is like.  I use the one that @pyrotenax linked to, but there are others.
There is a good sticky post at the top of this board that is worth a read:
http://community.virginmedia.com/t5/Networking-and-wireless/Getting-a-better-Wireless-Network-Signal...
Also bear in mind that your wireless environment is unlikely to be static and you might need to change channel again in the future due to the increasingly congested nature of the 2.4Ghz band, less so the 5Ghz band.
______________________
Scott
All Replies
  • 48
  • 7
Jack_C
Dialled in
Message 2 of 8
Bump with current upstream/downstream levels.
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Message 3 of 8
If you have an intermittent wireless signal , maybe other devices in the area are conflicting with the wifi channels ? You could possibly use something similar to this https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl=en_GB for android , to see how crowded they are , and if so choose another channel ?
Running ASUS RT-AC88U with Asuswrt-Merlin firmware
  • 3.01K
  • 383
  • 952
Message 4 of 8
The upstream doesn't look too good, you only have one channel with a status of "Success" when you should have at least two.  The other one looks to have struggled to lock on and given up after many retries.
When was the hub last restarted? You could try restarting the hub to see if it locks on to two upstream channels.  If it doesn't then you will probably need to book a tech visit to investigate why.
Scott
  • 48
  • 7
Jack_C
Dialled in
Message 5 of 8
Thanks @pyrotenax & @SCA1972
I chose a less congested channel in the past and still had some issues and when I posted on here back then it was suggested to stick to auto. I'll change it to a lesser used channel and restart the hub as suggested, then post my levels again as I'm not 100% sure what I'm looking for.
EDIT: I should've mentioned the hub gets restarted almost weekly.
What's the difference between Auto Compatibility and Auto Performance? I was set to Channel 11 (auto) and Auto Compatibility.
  • 3.01K
  • 383
  • 952
Message 6 of 8
@Jack_C I wasn't referring to a wireless channel but the upstream channels that the hub uses to talk to the VM network.  If it can't lock on successfully to at least two upstream channels then it could impact your service.  This is not something you can adjust, that would require a technician to visit and investigate the fault and maybe make changes.  Just reboot the hub and then post the upstream figures, no need to mess with wireless channels at this stage until you have a stable connection between the hub and the VM network.
Scott
  • 48
  • 7
Jack_C
Dialled in
Message 7 of 8
OK thanks.
I restarted without messing with the channels.
  • 3.01K
  • 383
  • 952
Message 8 of 8
Scott
