Rosie11
Just joined
What powerline is required
Hope this is the right area for help...
I've got my 2 tivo boxes and I'm wanting to connect them so I can watch shows recorded on 1 on the other, which and what powerline(s) would be best for this?
The main tivo as I call it is next to my hub and the other is in an upstairs room
Many thanks in advance
Helpful Answers
  • 3.98K
  • 202
  • 893
cybmole
Community elder
Re: What powerline is required
assuming that can even be done via powerline- I dunno exactly how the 2 Tivo thing works ( I would have thought it all goes via the virgin cables), then even  the cheapest powerline starter kit option will have more than enough bandwidth.
update: I see here that powerline is an option
http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27612&CURRENT_...
 so any basic starter kit ( 2 matching units + cables) should do the trick
e.g. this for £20 at amazon
https://www.amazon.co.uk/TL-PA4010KIT-V1-20-Powerline-Configuration-UK/dp/B01BECPIMC/ref=sr_1_sc_1?i...
All Replies
  • 3.98K
  • 202
  • 893
cybmole
Community elder
  • 7.26K
  • 305
  • 520
Hi Rosie11,
Welcome to the Community!
The post by cymbole sums it up perfectly! You can indeed use any powerline kit to connect your TiVo® boxes.
If you follow the setup in the link cymbole has provided, you should have no problem getting your Multi-room streaming up and running!
Give us a shout if you need anything else.
All the best Smiley Very Happy
Josh
