  • 5
stumccly
WIFI network
Hi, just got virgin media installed, got hub 3 , connected my main pc via ethernet, and went in to the hub admin to setup wifi network apart fromthe VMxxxxxxxx preinstalled network there was one with my name on it myname wifi network, this I am guessing is set up automatically ? however, i want to stick with the VMxxxxxx one albiet renamed. How do I get rid of the myname wifi network, network ???? thanks in advance to anyone who can help
  • 82
  • 6
  • 10
wanderey2
Up to speed
Re: WIFI network
As far as I am aware there should be no network preinstalled with customer's name as a network SSID. If you want to change you Wifi network name, just type in your web browser : http://192.168.0.1, login by using your settings password which can be found at the bottom of your SH3 . After logging in you can use "Configure your Wifi Network" option under Quick setup wizard, or from on the menu on the left, click on "Advanced settings"-->"Wireless"-->"Wireless signal", where you can configure both (2.4Ghz and 5Ghz) wifi networks names, passwords, etc.
Let us know how it goes.
