lottie1040
VoIP issues - EH15
Hi, I've got VM's 70Mb broadband and have long since had problems with VoIP, which I think is due to high jitter. No matter which service I use, and no matter whether I use the SuperHub on modem mode with another router or I use the SuperHub on router mode, VoIP keeps cutting out or stuttering, making it pretty much unusable. It's fine when I tether to my mobile and use its connection - but it really doesn't like my VM connection. WiFi calling is also affected, so I can't use it either. Is there maybe a problem on the line?
  • 7.2K
  • 173
  • 420
Re: VoIP issues - EH15
Hi lottie1040,
Welcome to the forums, I'm sorry to see you have been having trouble with VoIP.
I have taken a look at your connection and things seem to be ok from this side.
What type of VoIP systems are you using?
Keep us posted
Emma
lottie1040
Hi Emma,
This happens with Sipgate, Skype and also Three inTouch (WiFi calling app).
  • 10K
  • 294
  • 625
Hey there lottie1040,
Thanks for the additional info Smiley Happy
This sounds like a frustrating fault. Have you tested the speed of your connection at all? You can do this by going to speedtest.net and running a test.
I do know from experience that often with VOIP devices to work, we have to do port forwarding to allow access to certain ports. Do you happen to know what ports you'd need access too?
Speak soon,
Take care.
Heather_J
lottie1040
Hi Heather,
Apologies for the extremely late reply - I actually forgot about this topic...
Here's a speed test from relatively recently: http://www.speedtest.net/my-result/5856888439
I'm not sure which ports I'd need access to, but I'd have thought they must be open if VoIP is functioning (if not very well).
lottie1040
...actually, I've tested VoIP again, and it seems to be working fine now! I wonder what it was. Anyway, you can close this topic now, thanks.
