franka
Virginmedia WIFI for Android
I have downloaded "Virginmedia WIFI" for Android from the Playstore.
I have installed it on a 5.1.1 tablet and it appears to work okay.
I then downloaded it to an incar Android device, running 5.1.1. This device is definitely NOT rooted.
When i try to install the app it returns "cannot install on a rooted device"
Can anyone supply an answer please?
  • 992
  • 121
  • 441
Re: Virginmedia WIFI for Android
I think it means your in-car device is not an officially-approved Google device.
This might explain it -
http://www.howtogeek.com/241012/safetynet-explained-why-android-pay-and-other-apps-dont-work-on-root...
franka
My device must be CTI compatible as it shipped with Play Store and a number of google apps preinstalled..
It is not possible to root this device as developer mode is locked out with a 2D code. I asked the supplier if it is possible to root it and even they could not overide the code.
  • 992
  • 121
  • 441
Sounds like a bona-fide device then. Better wait for the Forum Team to pick this up.
May be an idea to state the device name and model.
