  • 5
jodelange
Message 1 of 10
Virgin won't load a particular website
I have virgin media and one particular website has stopped loading. I get the timed out message. It has loaded in the past. The website is yourfirstvisit.net
I have flushed my dns, tried with every browser, turned off all firewalls and defenders, tried a different proxy, tried multiple computers, ipads and iphones. I've tried wired and wifi. The website is not on the localhost banned list (I checked as an administrator) It can ONLY be an issue with virgin.
The website works if I turn off my virgin and use 3g.
Please help me get this website back!
Thanks, Jo
  • 329
  • 23
  • 84
KeithW
Fibre optic
Message 2 of 10
Re: Virgin won't load a particular website
Works and loads fine on Virgin services
All the voices in my head are my own voices - Find your own!
If I have helped you then please click on the "thumbs up" icon.
If you feel I have helped to solve your problem then please mark my message as a "Helpful Answer"
  • 13.91K
  • 743
  • 4.86K
Message 3 of 10
Works ok here as well
I've done some checking and it doesn't look to be intercepted by Websafe
C:\Users\timdu>dig -4 yourfirstvisit.net
; <<>> DiG 9.11.0-P3 <<>> -4 yourfirstvisit.net
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 54392
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;yourfirstvisit.net.            IN      A
;; ANSWER SECTION:
yourfirstvisit.net.     276     IN      A       199.189.111.68
;; Query time: 61 msec
;; SERVER: 194.168.4.100#53(194.168.4.100)
;; WHEN: Mon Jul 17 12:37:27 GMT Summer Time 2017
;; MSG SIZE  rcvd: 63
Post up a tracert - Here's mine as a comparison.
C:\Users\timdu>tracert yourfirstvisit.net
Tracing route to yourfirstvisit.net [199.189.111.68]
over a maximum of 30 hops:
  1     2 ms     2 ms     3 ms  192.168.0.1
  2     *        *        *     Request timed out.
  3    20 ms    13 ms    19 ms  perr-core-2a-xe-705-0.network.virginmedia.net [62.255.32.233]
  4     *        *        *     Request timed out.
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7     *        *        *     Request timed out.
  8    41 ms    18 ms    29 ms  nrth-ic-1-ae1-0.network.virginmedia.net [62.254.42.218]
  9    25 ms    21 ms    26 ms  m674-mp2.cvx1-b.lis.dial.ntli.net [62.254.42.162]
 10    80 ms    34 ms    34 ms  ae10.cr0-lon1.ip4.gtt.net [46.33.95.205]
 11   155 ms   149 ms   157 ms  xe-4-0-0.cr0-slc1.ip4.gtt.net [89.149.187.157]
 12   203 ms   170 ms   185 ms  as29854.xe-0-0-1.cr1.slc1.us.as4436.gtt.net [69.22.153.22]
 13   173 ms   173 ms   169 ms  206.130.126.14.west-datacenter.net [206.130.126.14]
 14   197 ms   194 ms   179 ms  199.189.111.68.static.midphase.com [199.189.111.68]
Trace complete.
Tim
________________________________________
Only use Helpful answer if your problems been solved.
  • 5
jodelange
Message 4 of 10
Thank you both for your response. It's so frustrating. I've run a tracert, though this means nothing to me! Can anyone help me get this website working on Virgin in my home? (also if I put 199.189.111.68 in the browser it still doesn't load)
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Users\Jo>tracert yourfirstvisit.net
1 3 ms 6 ms 1 ms 192.168.0.1
2 16 ms 13 ms 12 ms 10.244.56.1
3 13 ms 14 ms 14 ms croy-core-2b-xe-123-0.network.virginmedia.net [62.252.14.201]
6 47 ms 18 ms 18 ms nrth-ic-1-ae1-0.network.virginmedia.net [62.254.42.218]
7 20 ms 17 ms 13 ms m674-mp2.cvx1-b.lis.dial.ntli.net [62.254.42.162]
8 16 ms 18 ms 16 ms ae10.cr0-lon1.ip4.gtt.net [46.33.95.205]
9 142 ms 154 ms 149 ms xe-4-0-0.cr0-slc1.ip4.gtt.net [89.149.187.157]
10 190 ms 187 ms 188 ms as29854.xe-0-0-1.cr1.slc1.us.as4436.gtt.net [69.22.153.22]
11 188 ms 188 ms 188 ms 206.130.126.10.west-datacenter.net [206.130.126.10]
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
C:\Users\Jo>
  • 13.91K
  • 743
  • 4.86K
Message 5 of 10
Lets have a look then.
Well we can rule out DNS issues as we both get the same DNS lookup
Lets look at the ends of the tracerts
Here's mine:
Here's yours:
Notice that your tracert fails on the last hop.  This looks like an IP an on the part of the host.  Is this your website?
Tim
  • 5
jodelange
Message 6 of 10
Thanks Tim,
No it's not my website. I don't have anything to do with it at all. The website hosts are in the US and I'm in the UK. I did email them to ask if there was a site issue as I couldn't access it anymore and they said that everything was running fine.
Now what?
  • 13.91K
  • 743
  • 4.86K
Message 7 of 10
The best thing to do is ask them if your public IP is blocked for some reason.  Based on the tracert there's not an issue on the Virgin Network
You could try temporarily putting the hub into modem mode - which will give you a different public IP (you will get the old one back when you go back to router mode though).  If you can connect when in Modem mode this will prove an IP block on their part.
Note you can find your public IP by simply entering IP into a google search.
Tim
  • 5
jodelange
Message 8 of 10
Thanks, I'll let them know my public IP and hope it is blocked....that way at least it can be unblocked. Though I have no idea why little old me would suddenly be blocked by a travel agent's site in the US?!?! It also didn't die quickly, it was a slow death over a few weeks where the site would eventually load and then one day....dead...won't load at all.
I'm not going to turn my hub into modem mode for fear of not being able to turn it back, particularly if this computer isn't the wire in the first port. An engineer re-wired the house when we bought it so the hub is in the hall and hidden wires to all the rooms!
I'll get back to you when I hear something......
  • 5
jodelange
Message 9 of 10
Thank you, just to let you know it was a block on the server of the website I was trying to access. Apparently the site does that from time to time to random IP addresses. It's been removed and all working fine.Thanks for your advice and help.
  • 6.65K
  • 174
  • 438
Message 10 of 10
Sorry for the trouble experienced jodelange,
Many thanks for updating the thread with the progress of this.
Great to hear that this is all up and running for you now! Smiley Happy
Let us know if we can help with anything more,
Nat_J
