  • 9
Kido89
Message 31 of 39
Re: Virgin super hub 3 firmware
On 9.06 I spoke with  manager of tech support and he ensured me that they will roll out update TODAY 29.06.2017 but nothing happened so I made a call today and  spoke with 2nd line tech support manager  about firmware update and he told me that they plan to roll out it at the end of AUGUST.
I really losing hope now it's 3rd "official" date already. Now I just cross my finger that change to Superhub 2ac which I was offered will work.
  • 509
  • 9
  • 134
Guybrush85
Fibre optic
Message 32 of 39
Are you talking about a new firmware for the hub 3? If you are, I can assure you that there is no firmware in the pipeline with any official release dates. Heck, there isn't even a firmware in any trial capacity yet.
Look behind you, a three-headed monkey
  • 23
  • 7
astrohominis
Message 33 of 39
You may be 100% correct. This is sort of confusing though...
On the June 20 update (scroll down):
http://www.ispreview.co.uk/index.php/2017/03/virgin-media-prep-firmware-fix-superhub-3-latency-packe...
Last week we asked for an update on the Intel Puma 6 latency fix for Virgin Media’s SuperHub 3 (aka – Hub 3.0) routers and were told that the field trials of a new firmware update are due to “begin shortly“. Sadly we don’t know any more than that.
  • 509
  • 9
  • 134
Guybrush85
Fibre optic
Message 34 of 39
Problem with any of these 3rd party sources is... What name is behind any of these official VM statements? I wouldn't say it was uncommon (which is a polite as I can put this), for someone to speak to 2 people within Virgin Media and hear 2 completely different stories. I struggle taking things as gospel when they on Virgin Media pages themselves, never mind anything else.
Until there is anything official, I'm taking it all with a large pinch of salt.
  • 7
Joebulb74
Message 35 of 39
Hi guys mine is CH7465LG-NCIP-4.50.18.23-4-GA-NOSH is this up to date???
  • 20.74K
  • 554
  • 3.22K
Sephiroth
Message 36 of 39
If you are not in the UK (like Eire) then we can't help you as the Hub 3 in Eire is from Compal not Arris.
  • 7
Joebulb74
Message 37 of 39
But there is nothing like this in Ireland 🇮🇪 🤷‍♂️🤷‍♂️🤷‍♂️🤷‍♂️ No community 😭😭😭😭
  • 20.74K
  • 554
  • 3.22K
Sephiroth
Message 38 of 39
Yes there is.
https://www.boards.ie/ttforum/1546
  • 5
EricDude
Message 39 of 39
Hi, I've got a Superb 3 and its on 9.1.88T, still got issues with port forwarding, after 5 calls the other day to VM they finally sent me a new one and guess what the same software version, it doesn't want to update no matter how many times I re-boot it, and ideas? or do I need yet another hub 3. ;-(
