  • 77
  • 14
spikey673
Dialled in
Message 1 of 39
Virgin super hub 3 firmware
hi, I only joined virgin yesterday, had the VM SH3 installed and it's showing the firmware as 9.1.88T, is this the latest? Also for future ref is there a place where I can check if I have the latest firmware? Thanks in advance :-)
IF i have helped you, please give me kudos / mark me as helpful, thanks
Helpful Answers
  • 6.13K
  • 350
  • 1.02K
Message 2 of 39
Re: Virgin super hub 3 firmware
9.1.88T is the current firmware. You cannot update or change the firmware yourself. When a later firmware is released the Hub 3.0 will download and install it from the TFTP server at the CMTS.
Every time the modem locks to the CMTS it will check for new firmware.
200Mb(SH2 SH2AC Hub 3.0), 2 X V6 TV XL, Phone M. 100Mb Business (Hitron Hub).
All Replies
  • 6.13K
  • 350
  • 1.02K
Message 2 of 39
  • 77
  • 14
spikey673
Dialled in
Message 3 of 39
Thanks for the reply, so the answer is new firmware gets pushed to the hub as and when virgin release new updates to certain areas? Apart from this a reboot of the hub checks for latest firmware when it locks onto the broadband signal from the cabinet.?
  • 9.37K
  • 362
  • 2.31K
Message 4 of 39
Yes and yes. The only other way to get later firmware than what is on general release is to join one of the firmware trials.
I'm on trial firmware 9.1.116V.
  • 34
Hamrag
Message 5 of 39
I have the SH3 with firmware 9.1.8TT which has a bug that causes the connection to drop every ~30minutes, it will reconnect after a minute or two, but anything in progress gets trashed during the disconnection. VM's solution was to send me a new SH3 but it's programmed with the same firmware (pointless). So I will wait for the firmware update and in the meantime have reverted to the old modem (which works perfectly).
I don't want to re-attach the SH3 until I know that problem is fixed because installing it took 6 hours to get it running and it took 5 hours to get the old one back online. Can you confirm whether the new firmware Beta has fixed that issue? Is there a revision history somewhere for the SH3 firmware?
  • 9.37K
  • 362
  • 2.31K
Message 6 of 39
Yes, 9.1.116V firmware has fixed the port-flapping issue (which occurs every 34 minutes (plus seconds) or 2048 seconds to be exact, excluding reboot time). The firmware should be in all areas by end of November.
No, not outside the trial forum. Though if you read my back posts or Sephiroth's back posts you will get bits and pieces of what the differences are.
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 7 of 39
I got defrocked for providing information as useful as a 9.1.116V fix list!
  • 34
Hamrag
Message 8 of 39
I can believe that actually. God forbid anyone posting anything useful and helpful, such people must be punished!
I suspect VM don't want the revision history in the public domain because the number and severity of the bugs would be an embarrassment. Having said that, it might also reveal security holes that customers have been exposed to (and are still vulnerable to), so keeping those types of bugs under wraps is probably not unreasonable.
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 9 of 39
It's totally unreasonable.  If VM know full well that there is a vulnerability, it is their duty to fix it quickly.  Firmware versions come out very rarely and that would be inconsistent with the need for quick fxes due to vulnerabilities.   Everyone else, like Microsoft & Apple manage to get fixes out weekly or monthly - because it is correct practice.
I've been beating on for a couple of years about poor support practices at VM; secrecy about firmware fixes is one of the worst.
  • 9.37K
  • 362
  • 2.31K
Message 10 of 39
Which is why I'm not going to make a list for you, but if you look back at my previous posts and piece them together you will find all the information you require.
Indeed, not to mention the length of time they've been around.
No. Have to disagree here. All the bugs the people in the trial forum are aware of do not impact on security at all. VM do not talk about security issues full stop, on the trials or anywhere else.
VM have made several firmware revisions that were security related but did not say a thing about what was in them. However I was researching the security aspects of the hub since day 1, so have a fair idea, but I also can't tell you what I found. Smiley Happy
Generally speaking though nothing to be concerned about. The hub is now generally more secure than previous models (until the next new exploit is found).
