  • 6
itsbigfinn
Message 1 of 5
Virgin Media Super Hub - Making a very annoying constant ringing / whistling sound
Hi can anyone advise how i go about getting my Superhub box replaced. My VM box started this ringing noise a month or so a go but now its unbearable. It can be heard in another room.
Ryan
  • 22.25K
  • 851
  • 3.23K
Message 2 of 5
Re: Virgin Media Super Hub - Making a very annoying constant ringing / whistling sound
is it the box or the power supply?
  • 6
itsbigfinn
Message 3 of 5
The box thanks.
  • 6
itsbigfinn
Message 4 of 5
Please disregard. I believe it is the power supply that is the culprit. Can a new one be sent out please?
  • 8.32K
  • 359
  • 588
Message 5 of 5
Hi itsbigfinn,
Thanks for posting!
I can sort you out with a new Power supply, no problem!
I've sent you a private message (purple envelope at the top right of your screen) so I can grab some details and get this arranged for you.
Speak soon Smiley Very Happy
Josh
