dsmvmc
Virgin Media Fibre keeps dropping
Hi all, new to VM and this looks a helpful forum, so here goes...
Our 100Mb broadband keeps dropping - maybe once every couple of days or so, so more frustrating rather than terminal. I do tend to find switching to 2G means I can pick up a connection, but of course that's not the point!
On reading a couple of posts, I've seen a suggestion to C&P some info from my router..
thank all
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 267000000 235000000 243000000 251000000 259000000 275000000 283000000 291000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 133 113 114 115 116 134 135 136
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 2.27 2.57 2.48 2.52 2.36 2.30 2.33 2.23
RxMER (dB) 36.61 36.39 36.17 36.17 36.84 36.61 36.84 36.39
Pre RS Errors 3337 2755 548 1255 418 340 927 1061
Post RS Errors 295 300 311 896 402 302 902 1010
Upstream
US-1 US-2 US-3 US-4
Channel Type N/A N/A 2.0 2.0
Channel ID N/A N/A 1 2
Frequency (Hz) N/A N/A 37600000 31000000
Ranging Status Other N/A Success Success
Modulation N/A N/A 16QAM 16QAM
Symbol Rate (Sym/sec) N/A N/A 5120000 5120000
Mini-Slot Size N/A N/A 4 4
Power Level (dBmV) N/A N/A 51.00 51.00
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 3 0 1 0
T4 Timeouts 0 0 0 0
  • 8.28K
  • 514
  • 2.3K
Re: Virgin Media Fibre keeps dropping
Your upstream power levels are quite high,but in spec. Do they rise over time?
Because that would fit the symptoms you are seeing.
dsmvmc
Thanks Kippie - how do I check if the upstream are 'rising'?...
  • 8.28K
  • 514
  • 2.3K
Just post them again- in addition, set up a BQM
 HERE
 Run it for say 24 hrs, and post the result.
 Dont forget youll need to make sure your super hub is configured to reply to ICMP echo requests...
 That will monitor WAN side for connection drops. It runs their end, you dont have to leave your computer on.
dsmvmc
Hi Kippie, sorry for delay in replying. Now set up the BQM and the hub for echo requests. Updated download/ upload pasted below. Thanks again for your help.
Downstream
Frequency (Hz) 283000000 235000000 243000000 251000000 259000000 267000000 275000000 291000000
Channel ID 135 113 114 115 116 133 134 136
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 2.21 2.37 2.30 2.32 2.20 2.03 2.09 2.02
RxMER (dB) 36.17 36.17 35.97 36.17 36.61 36.61 36.39 36.17
Pre RS Errors 2497 2467 646 657 377 347 409 1071
Post RS Errors 300 291 292 297 317 306 309 958
Upstream
US-1 US-2 US-3 US-4
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 3 0 0 0
T4 Timeouts 0 0 0 0
  • 3.88K
  • 120
  • 203
Forum Team (Retired) Adam_L
Hi dsmvmc,
Thanks for keeping us in the loop with regards to your drops in connection, I apologise for any inconvenience caused.
I have run some tests from here and I can see that everything looks great! No errors or time outs inside the Hubs logs and all of the power levels are within the preferred ranges.
Are you still having these issues? If so, please respond to me here with a recent copy of your Hubs logs for me to compare with the data we have here.
When the connection drops, is there any noticeable change to the Hubs light sequence?
I look forward to hearing from you,
Adam.
