Pteropus66
VPN connection issues and SuperHub
I managed to fix most of my VPN connection issues by updating the security settings in the SuperHub to allow IPSec, PPTP and Multicast pass through. But, I still have one problem relating to a document management agent we use. Its just not recognised and won't connect. It seems to be a problem I only have with my home SuperHub (works everywhere else, even on public wifi).
Are there any other quirks of SuperHub that could cause this type of issue?
  • 10.59K
  • 311
  • 653
Re: VPN connection issues and SuperHub
Hey there Pteropus66,
Thanks for posting and a big welcome to the community Smiley Very Happy
Sorry to hear about the problems you're getting with regarding to using a document management tool.
It might be that we need to allow access by opening ports. I don't know the specific ports, but if you get in contact with the host of the document tool, they should be able to tell you.
We've got a guide here on how to apply port forwarding rules to your Hub.
I hope this helps,
Take care.
Heather_J
