  • 23
BatletUK
Message 1 of 7
VMDG485 SH2 Lan port faulty?
Ok, I think I've narrowed down the weird behaviour. Just touching the lan cable between the SH2 and router makes the internet connection speed erratic. Tried 4 different cables, all of which work fine elsewhere.
Careful "jiggling" of the plug in the SH2 results in a firm connection for hours, until it happens again Smiley Sad
VMDG485 in modem mode so can only use one of the lan ports. Would this be considered enough of a fault to replace the SH2?
Or would they say "It works in router mode so live with it"?
Pretty sure it's the SH2 and not the router, because I tried a different router with the same results.
  • 10.03K
  • 332
  • 877
Hero
Message 2 of 7
Re: VMDG485 SH2 Lan port faulty?
try another cable thats CAT6
Problem could be Docsis does the ready (tick) light start flashing? post downstream, upstream and logs
http://192.168.100.1/RouterStatus.html
  • 23
BatletUK
Message 3 of 7
All the cables claim to be Cat6 Smiley Happy
I'm convinced it's the lan port because when the speed is erratic and TBB shows low 40s Mbps and when it's working and 200+Mbps, without any apparent changes in the log or power levels. I was convinced it was external until wriggling the cable effected the results.
Sorry for the wall of graphics, but you did ask Smiley Happy
  • 23
BatletUK
Message 4 of 7
It's this image that explains my pointsppedtest2.jpgI  rebooted the SH2 because the upload speed was really poor*, but check the timestamps it came back at 40Mbps, then I wriggled the lan cable and the speed went up to 200Mbps and stayed there. The space of 20mins doesn't really seem external. Not saying it isn't, maybe there's some behind the scenes line monitoring or something going on Smiley Happy
*There's some T3 stuff going on, that's more recent than this issue.
  • 23
BatletUK
Message 5 of 7
Right, I've unplugged the lan cable and squirted the port with compressed air. Plugged it back in and it seems to be ok...
http://www.thinkbroadband.com/speedtest/results.html?id=14902830601339085729
Fingers crossed it was just dirty then.
Though somehow  I don't think it will be that easy ... Smiley Happy
  • 10.03K
  • 332
  • 877
Hero
Message 6 of 7
Where could your super hub be that you needed to use compressed air in the port thats normally never unplugged?
  • 23
BatletUK
Message 7 of 7
Assuming that was not a rhetorical question Smiley Happy It's on top of a tall cupboard, next to the router. It does get quite dusty but the compressed air was a last ditch effort before losing my patience and squirting it with contact cleaner.
Not sure VM would be happy about me doing that though. So I haven't. Yet.
I posted to see if others were going to say they had the same issue, guess it's not a common problem then Smiley Happy
