  • 17
cougarric
Using superhub as a modem?
My router is faulty and I can't access it on wifi anymore. Therefore I'm looking to use my superhub as a modem and my old linksys as a router.
Has anyone got experience of this, At the moment I've got my wired internet going straight into the plug from the superhub. Can this remain as it is and simply attach the linksys.
Any advice greatly appreciated.
  • 21.61K
  • 772
  • 3.09K
Re: Using superhub as a modem?
if the router is cable and not DSL you can log into the superhub GUI and set modem mode on the superhub. this will then enable only one of the sh ports to connect to the wAN port on your own router
