TVDad
Using a Cujo IDS with OpenDNS
Hi, I use OpenDNS and so I have my SuperHub configured modem only and run DHCP + NAT on my Apple Airport.  I would like to get and IDS like Cujo and configure it for Bridge Mode as I do not want to use Cujo for DHCP.
However, the IDS will only work in Bridge mode if my SuperHub does the DHCP.
Do you have or are you planning to provide a version of SuperHub in which I can set the DHCP server addresses?
  • 8.3K
  • 518
  • 2.3K
Re: Using a Cujo IDS with OpenDNS
You have approximately zero chance of that happening. And when I say approximately I mean exactly.
Couldn't you just go HUB in modem mode>airport as you currently have and bridge to CUJO from there if you want it in bridge mode?
