  • 6
bradzgoodz
Message 1 of 5
Trouble Forwarding Port 443
Hi there I have set up a OpenVPN server on my network I have opened up port 443 on the server and checked its open but when I set up port forwarding on my router I check the open ports using a online port checker and it is saying port is closed I have even tried using DMZ can anyone help me out
  • 10.13K
  • 338
  • 896
Legend
Message 2 of 5
Re: Trouble Forwarding Port 443
TCP or UDP for this OpenVPN?
have you run Wireshark to check it is forwarding?
  • 6
bradzgoodz
Message 3 of 5
TCP and I have used the 'UFW status' command to clarify the port is open on the server
  • 10.13K
  • 338
  • 896
Legend
Message 4 of 5
try in modem mode that it works over the internet.
  • 6
bradzgoodz
Message 5 of 5
the openvpn server relies on the router to address each device connected though
