  • 9
Chazmacq
Message 1 of 9
Superhub issues
My superhub has been working fine for ages but when I came home from work I couldn't connect, 4 or 5 reboots later started working. About an hour later same thing. I've had to do this throughout the weekend luckily I've been out a lot otherwise I'd go mad.
Helpful Answers
  • 16.47K
  • 1.37K
  • 3.36K
Message 2 of 9
Re: Superhub issues
hiya @Chazmacq would first need to do a check on the signal levels if you could goto http://192.168.0.1 clicking router status top right [no need to login] and copy/paste the downstream, upstream, network log don't worry about the formatting we can easily read it.. also could be area issue https://my.virginmedia.com/faults/service-status this will show regional issues.
  • 9
Chazmacq
Message 3 of 9
Re: Superhub issues
Super Hub
Sign In
home
Router Status
First Time Last Time Priority Error Number Description
19/06/2017 18:55:10 GMT 19/06/2017 18:55:10 GMT Warning (5) 66050310 Auth Success - Web login successful.
19/06/2017 13:59:57 GMT 19/06/2017 13:59:57 GMT Error (4) 68010302 DHCP WAN IP - removed
19/06/2017 13:59:08 GMT 19/06/2017 13:59:08 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
18/06/2017 18:11:40 GMT 18/06/2017 18:11:40 GMT Error (4) 68010302 DHCP WAN IP - removed
18/06/2017 18:10:48 GMT 18/06/2017 18:10:48 GMT Error (4) 68000407 TOD established
18/06/2017 16:05:10 GMT 18/06/2017 16:05:10 GMT Error (4) 68010302 DHCP WAN IP - removed
18/06/2017 16:04:19 GMT 18/06/2017 16:04:19 GMT Error (4) 68000407 TOD established
18/06/2017 15:34:29 GMT 18/06/2017 15:34:29 GMT Error (4) 68010302 DHCP WAN IP - removed
18/06/2017 15:33:39 GMT 18/06/2017 15:33:39 GMT Error (4) 68000407 TOD established
17/06/2017 10:27:04 GMT 17/06/2017 10:27:04 GMT Error (4) 68010302 DHCP WAN IP - removed
17/06/2017 10:26:15 GMT 17/06/2017 10:26:15 GMT Error (4) 68000407 TOD established
17/06/2017 07:21:25 GMT 17/06/2017 07:21:25 GMT Error (4) 68010302 DHCP WAN IP - removed
17/06/2017 07:20:33 GMT 17/06/2017 07:20:33 GMT Error (4) 68000407 TOD established
16/06/2017 23:03:28 GMT 16/06/2017 23:03:28 GMT Error (4) 68010302 DHCP WAN IP - removed
Refresh Clear Log
© 2010 Virgin Media. All rights reserved.
[MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
All Replies
  • 16.47K
  • 1.37K
  • 3.36K
Message 2 of 9
Re: Superhub issues
  • 9
Chazmacq
Message 3 of 9
Re: Superhub issues
Super Hub
Sign In
home
Router Status
Refresh Clear Log
  • 9
Chazmacq
Message 4 of 9
Re: Superhub issues
Super Hub
Sign In
Downstream
home
Router Status
Downstream
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 235000000 243000000 251000000 259000000 267000000 275000000 283000000 291000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 113 114 115 116 133 134 135 136
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 2.62 2.19 2.36 2.64 2.73 2.80 2.61 2.70
RxMER (dB) 36.61 36.39 36.39 36.39 37.09 36.84 36.61 36.61
Pre RS Errors Reset Counter 452 597 315 316 311 316 321 952
Post RS Errors Reset Counter 281 280 278 291 303 304 303 935
  • 9
Chazmacq
Message 5 of 9
Re: Superhub issues
Super Hub
Sign In
Upstream
home
Router Status
Upstream
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 N/A N/A 2.0
Channel ID 2 N/A N/A 1
Frequency (Hz) 30200000 N/A N/A 36800000
Ranging Status Success Other Other Success
Modulation 64QAM N/A N/A 64QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 47.50 N/A N/A 49.00
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
  • 9
Chazmacq
Message 6 of 9
Re: Superhub issues
Hi @paultechy I've copied those details across. Thanks for helping!
  • 16.47K
  • 1.37K
  • 3.36K
Message 7 of 9
Re: Superhub issues
nothing really showing an issue, could be area issue, would be around a week or less for a forum admin to reply or could contact broadband support via 150 / 0345 454 1111
  • 9
Chazmacq
Message 8 of 9
Re: Superhub issues
Typically it has worked fine over past 2 days. I checked service on Friday and found no local issues
  • 10.62K
  • 311
  • 654
Message 9 of 9
Re: Superhub issues
Hello Chazmacq,
Thanks for posting, hope you're well Smiley Very Happy
I just wanted to pop by and see how you're getting on since your last post. Hopefully your connection is still performing well, but if not just let us know and we will do our very best to help out.
Thanks again,
Take care.
Heather_J
