  • 1.64K
  • 25
  • 176
deans6571
Super solver
Superhub 3 Wired Connection: 2.4ghz or 5ghz?
Quick question;
I know that the Superhub 3 can pump out 2.4ghz and 5ghz when devices are connected via wifi however, what happens when you have a device connected via an ethernet connection (like a PC or a games console) - does it automatically use the quicker 5ghz speed?
__________________________________________________________
Twitter : @deans6571 / Xbox Live : Deans F
Helpful Answers
  • 2.96K
  • 378
  • 939
Re: Superhub 3 Wired Connection: 2.4ghz or 5ghz?
2.4Ghz & 5Ghz are wireless only bands, as Ethernet uses a cable it goes at the speed of the cable or the ports the cable is connected to (Usually 100Mbps or 1000Mbps) and is nothing to do with 2.4Ghz or 5Ghz.
Scott
All Replies
  • 2.96K
  • 378
  • 939
Scott
  • 1.64K
  • 25
  • 176
deans6571
Super solver
Thanks for clarifying.
Smiley Embarassed Smiley Happy
