  • 6
crispinhot
Message 1 of 13
Superhub 3 Port Forwarding not working
Basically trying to set my router/xbox one up for Play Anywhere and i need to add the last Port Forwarding rule in and it's not accepting the range 49000 - 65000 even though it says that's within range. Anybody able to help?
  • 10.82K
  • 309
  • 632
Message 2 of 13
Re: Superhub 3 Port Forwarding not working
Hi there crispinhot,
Sorry to read you are having issues with Port Forwarding.
Have you already got ports enabled at the moment?
If so, I found that adding the ports in ascending order work. Try this to see if it works for you and let us know how you get on.
Speak soon
Sam
  • 6
crispinhot
Message 3 of 13
yeah just tried it and it's still telling me invalid range of ports.
  • 10.98K
  • 323
  • 669
Message 4 of 13
Hey crispinhot,
Thanks for letting us know Smiley Happy
I can't be sure why it's not allowing you to add the last rule, I'll need to try and replicate this fault. I'll set a reminder for myself on Monday morning and I'll give it a go and let you know how I get on.
Catch up with you soon,
Take care.
Heather_J
  • 6
crispinhot
Message 5 of 13
alright then, thanks.
  • 10.98K
  • 323
  • 669
Message 6 of 13
Hey crispinhot,
Thanks for your patience Smiley Happy
I've tried numerous ports and I can't seem to replicate this error. I'm going to try and test different versions of Hub's to see if that makes any difference.
Apologies again for this,
Take care.
Heather_J
  • 6
crispinhot
Message 7 of 13
these are the other ports forwards i havethese are the other ports forwards i havethis is the problemthis is the problem
  • 6
crispinhot
Message 8 of 13
hope this helps
  • 10.98K
  • 323
  • 669
Message 9 of 13
Hey crispinhot,
Thanks for your patience with this Smiley Happy
I can't seem to replicate this fault so we'll have to consider to be a local issue to your Hub. Are you able to perform a full factory reset (pin into reset hole for 30 seconds) and try the ports again, if this continues to fail I'll order a replacement for you.
Thanks again,
Take care.
Heather_J
Fransuarez100
Message 10 of 13
I'm on a superhub 3 and getting exactly the same fault.
Trying to do the same for the same reason i.e. play anywhere on Xbox one. The first two sets of ports forward correctly but 49000-65000 does not work. Says it's invalid so I put 0 in and it says it needs to be between 1 and 65535 which it obviously is. Works on superhub 2ac can't understand it?
Fran
