perprods
Message 1 of 8
Superhub 3 DNS doesn't work on wired connections
After getting my second new Superhub 3 in a week, i am still experiencing a issue with the DNS on the router. The same issue on both new hubs. All working fine with the old Superhub 2....
Wireless works without problems.
Wired connection to my devices/computers and network don't work. The only fix i can find is to manually change on those devices the DNS to a google 8.8.8.8 - then i get a connection!
Awaiting a call back within 5 days........
Any suggestions / thoughts etc?
perprods
Message 2 of 8
Re: Superhub 3 DNS doesn't work on wired connections
Still doesn't work.............................
  • 14
envoycdx
Message 3 of 8
You set the DNS on the router on the PC's / devices? If you log into the router, someone hasn't hardest a DNS address in there have they?
  • 10.13K
  • 338
  • 896
Legend
Message 4 of 8
VM DNS might be down in your area run CMD for the following:
nslookup bbc.co.uk 194.168.4.100
nslookup bbc.co.uk 194.168.8.100
perprods
Message 5 of 8
Theres obviously a fault within the router. This is the 2nd brand new router in a week. The DNS doesn't work via wired connection.
The only fix is to change the DNS from 192.168.0.1 to googles 8.8.8.8 - then i get a connection...... the fault can only be on the router. The superhub 2 was working fine before the 3 went in....
a week on and still no answer... every time i try and ring Second Line in swansea where I'm told to ring no-one answers....
  • 10.13K
  • 338
  • 896
Legend
Message 6 of 8
192.168.0.1 goes to 194.168.4.100 and 194.168.8.100 so by testing with nslookup posted above you test them.
perprods
Message 7 of 8
Yes been through all of this over the phone, the DNS on the router simply doesn't work. The last call i had he said they had discovered a fault with the DNS and were passing it to developers. Nslookups just time out.
Anyone else have issues with the wired connection on the super hub 3?
  • 10.13K
  • 338
  • 896
Legend
Message 8 of 8
If you did the nslookup as posted above then the fault is VM DNS for your area.
