Jak032
Message 1 of 16
Superhub 2ac losing connection every 20-30 minutes
Hi there, for the past week or so our connection has been dropping every 20-30 minutes but reconnects within a matter of seconds.
It doesn't sound like much of a problem but when streaming Netflix or playing games online it causes everything to shut down as it has still lost its connection. We have a Superhub 2ac and I have some info I think is useful, please let me know if there is anything else you need.
I have already tried a number of things such as restarting the hub box and resetting connections on the TV, PC, tablets and consoles, but nothing has worked as of yet.
Thanks in advance.
First TimeLast TimePriorityError NumberDescription
24/01/2017 06:57:33 GMT24/01/2017 06:57:33 GMTCritical (3)82000200No Ranging Response received - T3 time-out
24/01/2017 04:22:02 GMT24/01/2017 04:22:02 GMTCritical (3)82000200No Ranging Response received - T3 time-out
23/01/2017 21:31:37 GMT23/01/2017 21:31:37 GMTError (4)68000407TOD established
Time Not EstablishedTime Not EstablishedNotice (6)84000510Downstream Locked Successfully
23/01/2017 16:01:00 GMT23/01/2017 16:01:00 GMTError (4)68010400DHCP REBIND WARNING - Field invalid in response
23/01/2017 16:00:23 GMT23/01/2017 16:00:23 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 15:59:48 GMT23/01/2017 15:59:48 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 15:58:39 GMT23/01/2017 15:58:39 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 15:56:21 GMT23/01/2017 15:56:21 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 15:51:44 GMT23/01/2017 15:51:44 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 15:42:30 GMT23/01/2017 15:42:30 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 15:24:03 GMT23/01/2017 15:24:03 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 14:47:08 GMT23/01/2017 14:47:08 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 13:33:18 GMT23/01/2017 13:33:18 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 11:05:39 GMT23/01/2017 11:05:39 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 06:10:21 GMT23/01/2017 06:10:21 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
23/01/2017 01:04:18 GMT23/01/2017 01:04:18 GMTCritical (3)82000200No Ranging Response received - T3 time-out
22/01/2017 20:19:43 GMT22/01/2017 20:19:43 GMTError (4)68010100DHCP RENEW sent - No response for IPv4
22/01/2017 12:43:18 GMT22/01/2017 12:43:18 GMTCritical (3)82000200No Ranging Response received - T3 time-ou
  • 65
  • 11
cosymart
Dialled in
Message 2 of 16
Re: Superhub 2ac losing connection every 20-30 minutes
If it's any help my Super Hub 2 has had to be re-booted 3 times today as the internet got slower and ground to a halt, rebooted and than all OK for a few hours and then off we go again. Did think about ringing support but didn't relish wasting 2 hours of my life...... :-(
Jak032
Message 3 of 16
It's strange, ours doesn't get slower. Just disconnects for a matter of seconds, then re-connects. But when streaming videos or playing games online it will cause you to log out. It was the worst last night, happening every 6 minutes or so.
  • 2.76K
  • 224
  • 843
Dave_cq
Trouble shooter
Message 4 of 16
What version of the SH2ac software are you on.  If it's 'upgrade' v2.01.11 then that could well be the problem because they got it very wrong.  VM are in the process of sending out another 'upgrade' which is simply rolling back to the original tried and trusted v1.01.11 so you may want to keep rebooting your hub every few hours to see if the roll-out has reached your hub yet.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
Jak032
Message 5 of 16
Thanks Dave. Seems like we are on V2.01.11. I'll try a couple of times the next few days. Thanks for your suggestion.
  • 400
madmanx
Message 6 of 16
Dave_cq u said virgin is about to roll back the 2ac update back to v.1.01.11, where did u read this? Is there a post here saying that?
  • 22.26K
  • 851
  • 3.24K
Message 7 of 16
  • 400
madmanx
Message 8 of 16
Thanks apcyberax
  • 400
madmanx
Message 9 of 16
Will all the superhub 2acs on firmware v2.01.11 receive the update back to v1.01.11?
  • 2.76K
  • 224
  • 843
Dave_cq
Trouble shooter
Message 10 of 16
Logically they should.  You may just need to keep rebooting (power off and back on) your hub from time to time to get the download.
Electron
