  • 8
dlapi
Message 1 of 7
Superhub 2 problems
Recently I've noticed that the connection to my 3 children and my wife's mobile keeps on dropping.
This seems random and switching their phones off doesn't solve the problem. The only solution is to power down the Hub and then they can reconnect. It happens to all four of them and not at the the same time. They all have android phone from different brands. It's driving me crazy
  • 10.82K
  • 308
  • 632
Message 2 of 7
Re: Superhub 2 problems
Hi there dlapi,
Thanks for taking the time to post on the community.
Sorry to read you are having an issue with the wireless network.
Have you tried to change the wireless channel to see if that will help? As there could be an issue with interference within the property.
Do the devices connect to the 2.4 GHz or the 5 GHz network?
Let us know how you get on
Sam
  • 8
dlapi
Message 3 of 7
Just to let you know I changed the channels. I also used a WiFi analyser to find the best channels.
Unfortunately​ this doesn't appear to work.
Switching the router off fixes it for a short period but after a few hours the same happens again
  • 10.02K
  • 332
  • 876
Hero
Message 4 of 7
For better stable wireless maybe use modem mode with your own wireless router.
  • 6.62K
  • 174
  • 438
Message 5 of 7
Thanks for updating the thread dlapi and sorry to hear about the connection trouble experienced.
I've checked everything from this end and I'm unable to detect any fault via the equipment or network at the moment.
How have things been for you since posting?
Nat_J
  • 8
dlapi
Message 6 of 7
I'm afraid it's still happening
  • 12.48K
  • 353
  • 1.45K
Message 7 of 7
Hi dlapi,
Do you know if the 2.4GHz and 5GHz frequencies use the same password or not? They should both be distinguishable by the -2g and -5g endings to the network names. If the passwords are the same for both please change one of them and reconnect your devices.
  • Navigate to 192.168.0.1 via your browser.
  • Log in using the access info on the base of the Hub (or use your own password if you've already changed it from the default).
  • Click on Wireless Network Settings.
  • Change the Passphrase or Security Key for one of the frequencies.
  • Click on Save Settings.
  • Reconnect your devices.
If the above doesn't help please reset your Hub back to factory settings.
If that fails post an update on here and I'll arrange for a replacement Hub to be sent out to you.
Smiley Happy
Jen
