  • 5
jonahwigan
Message 1 of 96
Superhub 2 dropping Wifi constantly
Please can someone help me.
Our Superhub keeps dropping the Wifi.
I have changed the wifi channel, restarted the superhub and hard reset the superhub but it keeps losing the wifi.
It is now utterly unusable and the telephone support is beyond dreadful.
Downstream
DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 283000000 Hz 267000000 Hz 275000000 Hz 291000000 Hz 299000000 Hz 307000000 Hz 315000000 Hz 323000000 Hz
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 107 105 106 108 109 110 111 112
Modulation QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256 QAM256
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) 5.2 dBmV 5.7 dBmV 5.6 dBmV 4.9 dBmV 5.8 dBmV 6.1 dBmV 5.6 dBmV 5.4 dBmV
RxMER (dB) 38.2 dB 37.9 dB 38.0 dB 38.2 dB 38.1 dB 38.2 dB 37.9 dB 37.9 dB
Upstream
US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 N/A N/A
Channel ID 3 1 N/A N/A
Frequency (Hz) 24400000 Hz 37600000 Hz N/A N/A
Ranging Status Success Success N/A N/A
Modulation QAM16 QAM16 N/A N/A
Symbol Rate (Sym/sec) 5120000 5120000 N/A N/A
Mini-Slot Size 128 128 N/A N/A
Power Level (dBmV) 39.5 dBmV 43.3 dBmV N/A N/A
T1 Timeouts 0 0 N/A N/A
T2 Timeouts 0 0 N/A N/A
T3 Timeouts 0 0 N/A N/A
T4 Timeouts 1 1 N/A N/A
Thank you in advance
One very angry Virgin Media customer
  • 19
inadau
Message 2 of 96
Re: Superhub 2 dropping Wifi constantly
Commiserations - I am in exactly the same situation, had the same experience: telephone support hopeless, after making me try all the usual things like switching channels, rebooting hub etc. they asked me to wait while they were doing more tests, then they hung up. So far support here has not helped either, I am seriously considering to give up and buy a cable router ( the Asus RT-N66U is highly recommended) and use the Virgin hub just as a modem.
another very angry virgin customer
  • 39
adamfoz
Message 3 of 96
I'm in a similar situation. The call centre have reset the router to monitor and check to see if the wifi IS dropping. On the plus side, we were told we are eligible for a free upgrade on our BB speed. Smiley Happy
Debating whether to plug in our 2nd router again for Wifi downstairs??
  • 19
inadau
Message 4 of 96
I wasn't offered a free upgrade to BB speed, which quite honestly I need like a hole in  my head. It would be more honest,if they reimbursed us a month's fee.
  • 13.14K
  • 375
  • 1.07K
Moderator
Moderator
Message 5 of 96
Hi jonahwigan,
Thanks for posting and welcome to the forums, though sorry to hear of the wireless connection problems. wireless by it's very nature can be difficult to troubleshoot, although I'm not ruling a potential problem with your Superhub.
It may be worth checking out the troubleshooting guide here, certainly dropping the wireless mode to 54Mbps and switching the security from auto to WPA2_PSK has been reported as helping reduce drop outs with some devices.
Ralph_R
Forum Moderator
  • 165
  • 8
  • 17
Tomo72
Superfast
Message 6 of 96
If you're using a laptop, it's well worth updating the wireless adaptor drivers to the manufacturers latest, don't rely on Windows update
  • 5
jonahwigan
Message 7 of 96
Thanks for the suggestions.
I'll report back.
I still think it is a hardware issue and I still think your telephone tech support is dreadful.
These amendments could have been suggested by telephone support ages ago!
  • 6
sedw
Message 8 of 96
I had the same problem and solved it by connecting my old Netgear router. The Virgin wbsite recommends switching the Superhub to modem only in those circumstances but I have found that unnecessary. I expect that any decent router would do. Why Virgin supply substandard equipment defeats me.
  • 12.48K
  • 353
  • 1.45K
Message 9 of 96
Hi to all who have posted on here,
Really sorry for the wireless disconnections you've been experiencing and I hope you don't mind me posting to all of you right now.
I just want to clarify a couple of things first, after which I'll run individual diagnostics for each of you.
  • Firstly, how often is the wifi disconnecting (hourly, daily for instance)?
  • When the wifi disconnects do wired (via Ethernet) devices sustain a connection?
  • When wifi drops, is any error message displayed (on the desktop where the wifi connection is shown)?
  • Does this occur on 2.4GHz or 5GHz or both?
Next, please read this which explains some of the issues that can factor in wireless interference and please follow the suggestions offered.
Please post back on here and I'll then determine what we can do to help.
Many thanks Smiley Happy
Jen
Jen
  • 6
sedw
Message 10 of 96
Hi Jen
In reply to your bullet points
When watching catch up the wifi drops almost every 10 mins
Wired remains OK
The TV sometimes (not always) displays a message saying the internet connection is lost
I have not tried the last point
As I said in my post, I have solved the problem by switching the Superhub to modem and reconnecting my old router (a standard Netgear one). I doubt very much that this is a channel problem as I live in a large detached house and we rarely get other people's wifi signals. The fact is that my old standard Netgear router worked (and works) well but the Superhub does not as is amply demonstrated by the posts. I simply ask why Virgin supplies a substandard piece of equipment.
