  • 6
domenek
SuperHub2 Drooping Wifi connection Faulty router?
Hi, Since last few weeks Iam having a problem with speed on my Wifi..
Speed is getting dropped to 0.5-1mbps
I am loosing connection few times a days or speed connection is dropping to 1mb/s
After router reboot it's sorts out, but come back after 20-24 hours time. I am having this broadband almost a two years, so basically I need to restart my router every day :/
I dont have any problem on Wired connection, Problem occurs only on Wifi on mutltiple devices.
It is looks like the router is faulty ?
 Is it possible to arrange replacement?
Looking a advice as this getting frustrating me !
  • 10.82K
  • 308
  • 631
Re: SuperHub2 Drooping Wifi connection Faulty router?
Hiya domenek,
Hope all is well. Thanks for taking the time to post back on the community. It's nice to have you here.
My apologies that you are having issues with the broadband connection.
I've checked your account for any issues, there are no faults reported and the network is running stable which is good.
I can see from your first thread, that I mentioned to try and change the wireless channel to improve the connection. Did you manage to try this at all?
Hope to hear from you soon
Sam
  • 6
domenek
Hello,
Yes I tried that already, It is looks like my Router is fauly, only reboot fixing performance for another 20-30hours.
  • 55
  • 9
oldgit
Dialled in
I also have problems with regular drop outs.
  • 7.26K
  • 306
  • 520
Hi domenek,
Thanks for getting back to us!
I'd like to look into this further for you. I've sent you a private message (purple envelope at the top right of your screen) so I can grab some more information from you.
Speak soon Smiley Very Happy
Josh
  • 7.26K
  • 306
  • 520
Hi oldgit,
Thanks for posting.
Sorry to hear you're having trouble with this too.
Can you try changing the Wireless Channel for me to see if that helps?
Look forward to hearing from you! Smiley Very Happy
Josh
