LucasWaragowski
SuperHub 3.0 Wired Connection Keeps Cutting Out
I recently got the VIVID Gamer package from Virgin and I was sent a SuperHub 3.0 and ever since I installed it my connection has been cutting out every 10-30 minutes...
I am connected with my Ethernet Cable and I know my Cable is fine as it had no problems on my old Hub.
I was wondering if anyone had any idea what I could do?
Should I down grade?, I have no idea what to do and as I work online I need this problem fixed as fast as possible.
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Re: SuperHub 3.0 Wired Connection Keeps Cutting Out
Hi LucasWaragowski,
Thanks for the post! I am sorry to hear about your issues with your Hub 3.0 wired connection cutting out, I apologise for any inconvenience caused.
I've tried to run some checks from here but I was unable to locate any of your details via your forum account. I will need some information from you before I can proceed with diagnostics.
I'll send you a PM (purple envelope at the top) detailing what's required to proceed with diagnostics. Please respond to me there and I'll ensure this all gets sorted for you.
Take care,
Adam.
