hendra173
SuperHub 2 - Refusing passwords and dropping out
My super hub 2 is getting more and more unreliable.  The 2g network keeps dropping out and requires devices to re-enter the password, when i attempt to do this i am told constantly that the password is incorrect.
It is possible to fix this by re-setting the router but i am needing to do this almost daily in order to get things working.  My internet speeds also seem to be affected.
Any help would be great
Many Thanks
Helpful Answers
  • 1.33K
  • 101
  • 244
stevedh2
Knows their stuff
Re: SuperHub 2 - Refusing passwords and dropping out
prob hub on the way out, might be worth giving it a pinhole reset just to see if that helps. Might also be worth getting a wifi scanning app to see if you're getting much interference from neighbours.
BTW on here you'll have to wait 1-2 weeks before a member of Virgin staff can get to this.
All Replies
  • 1.33K
  • 101
  • 244
stevedh2
Knows their stuff
  • 10.82K
  • 309
  • 632
Hi hendra173,
I'm sorry to read you are having an issue with the wireless connection.
As stevedh2 mentioned, it may be worth completing a factory reset of the Super Hub to see if that will help. In regards to the speeds, if you complete a speed test through a wired connection, what speeds do you achieve?
I was unable to locate your account, to check for any issues on your connection. If you can send me a Private Message confirming your address, I can look into this further.
Let us know how you get on
Sam
