tazisbones
Super hub port not working
Hi, I have all 4 ports hardwired to pc's ps4 etc but one port has stopped working. If I swap the cable for that of another port the connection is fine so it's definitely the port at fault. Any ideas?
Helpful Answers
  • 20.72K
  • 553
  • 3.21K
Sephiroth
Re: Super hub port not working
The VM bods take a week or so to get to thread. If it's vital that you have a replacement hub before Chrimbo, that's unlikely to happen. You might ths care to drop into Maplin or somewhere and buy a 4 port switch to provide the extra connectivity.
All Replies
  • 20.72K
  • 553
  • 3.21K
Sephiroth
tazisbones
Thank you for that, it's my first query through the site and any guidance is appreciated. I don't need it urgently and I have enough cover for my equipment just now. But may just contact customer services directly. Thanks again.
  • 20.72K
  • 553
  • 3.21K
Sephiroth
Fine. The reason I didn't just calling it in is that if you get to the offshore call centre, it's a total crap shoot as to whether or not you get a useless script monkey.
tazisbones
Good point, will maybe hold off with that plan then. Thanks for the tip.
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Hi tazisbones,
Thanks for getting in touch to let us know that one of the ports on your Hub has stopped working, I apologise for any troubles incurred.
I would need to arrange for a replacement Hub to be sent out to you, I will send you a PM (purple envelope at the top) if you could respond to me there and confirm a few details, I will get this sorted.
Take care,
Adam.
