dprior46
Super hub 3.0 wifi crashing
I've just got vivid 200 gamer on a super hub 3.0 and the wifi keeps dropping out , then the wireless network is available on the network list but it won't let me connect , it seems this is a common problem, has anyone found a cure yet?
  • 10.62K
  • 311
  • 654
Re: Super hub 3.0 wifi crashing
Hey dprior46,
Thanks for your post, welcome to the forum!
Sorry to hear about the troubles you're having with your wireless connection, I know this can be frustrating. How is your hard-wired connection?
I've checked your Hub and I don't see anything out of the ordinary with it. It's possible that you just need to select a different wireless channel. Take a look at our help article here - Changing the Virgin Media router's wireless channel / frequency it'll show you how to log into your Hub and make the changes.
Hope this helps, please get back to us about your hard-wired connection.
Take care
Heather_J
