milroypj
Message 1 of 7
Super Hub in Modem mode and Access to GUI not possible
I have my Super Hub in Modem mode connected to an Apple Airport Time Capsule which I use for back up and providing the WIFI for my home network.
The  Apple Airport Time Capsule is set to DHCP and NAT and this works fine for all services apart from accessing the Super Hub GUI.
Software Version "V2.39.02"
Hardware Version 2.00
Entering 192.168.100.1 in a browser address bar gives "Failed to open page"in Safari and
This site can’t be reached
192.168.0.1 took too long to respond.
in Google Chrome
Yet it is possible to ping 192.168.0.1 using Mac OS Terminal
Can you advise
  • 576
  • 27
  • 60
khenryashley
Rising star
Message 2 of 7
Re: Super Hub in Modem mode and Access to GUI not possible
Have you tried another browser or have you a VPN running?
milroypj
Message 3 of 7
Firefox also reports
The connection has timed out
The server at 192.168.0.1 is taking too long to respond.
I have no VPN running either.
  • 9K
  • 758
  • 1.88K
Message 4 of 7
Did you try http://192.168.100.1 in Firefox?
milroypj
Message 5 of 7
Sorry, I didn't type the correct IP, the correct one also reports
Unable to connect
Firefox can't establish a connection to the server at 192.168.100.1
milroypj
Message 6 of 7
Should have said I can ping 192.168.100.1 and get a response
iMac-2:~ paulmilroy$ ping 192.168.100.1
PING 192.168.100.1 (192.168.100.1): 56 data bytes
64 bytes from 192.168.100.1: icmp_seq=0 ttl=255 time=1.753 ms
64 bytes from 192.168.100.1: icmp_seq=1 ttl=255 time=0.603 ms
64 bytes from 192.168.100.1: icmp_seq=2 ttl=255 time=7.342 ms
64 bytes from 192.168.100.1: icmp_seq=3 ttl=255 time=7.323 ms
64 bytes from 192.168.100.1: icmp_seq=4 ttl=255 time=1.164 ms
^C
  • 9K
  • 758
  • 1.88K
Message 7 of 7
I would check you have not got any proxy servers enabled.
Try rebooting the hub.
If that fails a factory reset of the hub should work, (Bear in mind all passwords will revert back to their default values printed on the hub) if not the hub is faulty.
