Patfh
Message 1 of 12
Super Hub 3 and Chromecast 2
I cannot connect my Chromecast 1 or 2 to my new Super Hub 3. As far as I can see from Googling, there is no solution, until Virgin release a fix. The default settings seem to correctly match any ideas specified for fixing the issue which generates the "We weren't able to discover your Chromecast on the network. This may require a small change to your Wi-Fi settings." Is there a fix or are we waiting for Virgin to create one.
I still have my old modem (Super Hub v1). If I reconnect this will it work until a fix is released.
Thanks for any advice.
Tags (2)
Helpful Answers
  • 9.37K
  • 362
  • 2.31K
Message 5 of 12
Re: Super Hub 3 and Chromecast 2
Patfh wrote:
You have the 9.1.88J5 release firmware which has a known problem with Chromecast.
There is a fix in the latest firmware 9.1.88S and 9.1.88T being used on the Hub 3 trial. Before you ask I don't know when that will be released to other non-trial Hub 3 users and neither do the VM Forum Team at the moment.
Ask the Forum Team for a SH2ac and they will send you one, which you can use while you are waiting for the next release firmware for the Hub 3.
All Replies
  • 6.13K
  • 350
  • 1.02K
Message 2 of 12
are you on a Vivid package?
200Mb(SH2 SH2AC Hub 3.0), 2 X V6 TV XL, Phone M. 100Mb Business (Hitron Hub).
Patfh
Message 3 of 12
Yes. Vivid 200. This worked perfectly with Super Hub v1.
  • 6.13K
  • 350
  • 1.02K
Message 4 of 12
Nope there is no config file for the SH1 for Vivid 200.
  • 9.37K
  • 362
  • 2.31K
Message 5 of 12
Patfh wrote:
Patfh
Message 6 of 12
Thank you both for the excellent reply. I have no expectation of a fix anytime soon, but am grateful for your workaround.
I have had marginal success getting the Chromecast to connect, using the Wi-Fi rename workaround. I'll post more detail when I get back home and have access to my router.
Thanks again for taking time to respond and the clarity of your answer.
Tags (2)
Bunker_MonkeyUK
Settling in
Message 7 of 12
I have a Chromecast and a Superhub 3.0 (& we never had this issue before VM)
We can only get it working right after a reboot where we can cast from any device once but then it'll fall off once we can device (iPhone 5, Windows 10 PC etc).
Waiting urgently for the new firmware!
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Message 8 of 12
@ForumTeam
It seems to me that if VM can launch the Hub 3 with the J5 firmware, which isseriously flawed in router mode, then they could surely issue the much better 88T that the triallists have.
Can the Forum TEam got that transmitted upstairs, please?
Spurge54321
Message 9 of 12
Same problem here. Chromecast v1 and v2 fail to connect to the Super Hub 3. Very frustrating. As a new customer is it possible to get hold of one of the Super Hub 2's as I understand it worked perfectly well with them?
  • 9.37K
  • 362
  • 2.31K
Message 10 of 12
Read the last line of my post above.
