stuf83
Super Hub 3 Wifi Question
I have had my Super Hub 3 installed today and everything is working ok apart from some of my devices connect on 2.4 and not 5ghz wifi. The devices are capable, iphone 6s, Ipad etc but for some reason the hub puts them on 2.4. My laptop on the otherhand connects straight on 5ghz. Is there anyway to either seperate out the 2.4 and 5ghz onto seperate SSIDs or can i force devices on to 5ghz?
Any help is greatly appreciated?
Stuart
Helpful Answers
  • 20.74K
  • 554
  • 3.21K
Sephiroth
Re: Super Hub 3 Wifi Question
You can go into the Hub 3 GUI, log in, navigate to the WiFi setup pages and change the SSID names.
All Replies
  • 20.74K
  • 554
  • 3.21K
Sephiroth
