  • 81
  • 5
rockies
Message 1 of 14
Super Hub 3 - Modem Mode Wifi Issues
Is anyone else having this problem on there superhub 3.0
Helpful Answers
  • 10.02K
  • 332
  • 877
Hero
Message 8 of 14
Re: Super Hub 3 - Modem Mode Wifi Issues
As I said its likely a display bug when in modem mode from other posts on old firmware for the hub 3 when in modem mode the Network access state showed denied when you was allowed which that got fixed by the looks of it.
If the wireless was really on when in modem mode you would see it wouldn't you by it SSID?
All Replies
  • 10.02K
  • 332
  • 877
Hero
Message 2 of 14
Your in modem mode so you have your own router/equipment to do the wireless not the hub 3. VM will not re-design the hub 3 to let you use wireless from the hub 3 with your own router getting the WAN IP in modem mode but given that you can get routers with wireless or a AP to a router setup they likely never will re-design the next hub unless they will.
So modem mode one WAN IP on one MAC to do NAT get your own router for wireless a router with wireless or AP to a router
or
Router mode it has the WAN IP with NAT and wireless
  • 81
  • 5
rockies
Message 3 of 14
That's not what I'm wanting to do. The problem is why is the wifi active when in modem mode. This shouldn't be happening
  • 514
  • 27
  • 121
deviousiphone
Rising star
Message 4 of 14
Hmm i would say try a hard reset but I have heard that may risk dropping you back to the older firmware, please wait for someone to reply that has a little more experience of this as I didn't get the beta firmware before I went back to the SH2AC
  • 285
  • 10
  • 49
BrianY
Superfast
Message 5 of 14
Slight difference to message shown, wireless (off), internet (enabled modem mode) and telephone (error (tel 1) (error tel 2).
Only light on front red/blue, to signify modem mode.
  • 10.02K
  • 332
  • 877
Hero
Message 6 of 14
Oh that...its likely not enabled then and if it was you would see it by wireless? Likely its a display bug for when your in modem mode based on router mode setting for wireless being on but really its off in modem mode...or so it should be...If you want you can quickly change to router mode disable the wireless then change back to modem mode where it should display it as off but likely its off either way in when in modem mode.
  • 81
  • 5
rockies
Message 7 of 14
Already tried that several times. Even spent 1.5hrs with phone support on Tuesday night and even they couldn't explain it and then gave the usual excuse that it was a network wide problem. It's done it before but that was when it was on a trail firmware ages ago. Only problem is its playing havoc with the wireless networks.
  • 10.02K
  • 332
  • 877
Hero
Message 8 of 14
  • 81
  • 5
rockies
Message 9 of 14
Pressed the wrong button it's not sorted as the super hub 3 ssids do show. Tried putting it in router mode and changed the ssids and then disabled wifi then put it in modem mode and the 2 ssids for the super hub wifi both appear. Tech support had a look 2 days ago and even they just stated it was a network issue and they are aware of it and not to worry. Thing is though it's making the routers wifi signals congested as it's fixing onto the same channels even if I set up router to use different ones
  • 10.02K
  • 332
  • 877
Hero
Message 10 of 14
It might have something to do with VM public Wi-Fi weather or not they have solved allow modem mode and public Wi-Fi is another issue but its a bit bad you can't turn the wireless off right their or again its a bug.
What you can try and do is login to VM and find the opt-out public Wi-Fi option which might trigger it to turn off.
