JNE
Just joined
Speed issues with BIG-IP Edge Client and Superhub 3
Work laptop using BIG-IP Edge Client connecting to Superhub 3 (200Mbps). Colleague with similar issues but with a superhub 2 has resolved by enabling PPTP-Pass-Through and Multicast Pass-Through under Security -> Firewall options.
Is this available on the 3 - I can't find it!
  • 12.78K
  • 1.62K
  • 3.78K
Re: Speed issues with BIG-IP Edge Client and Superhub 3
Unfortunately the passthrough options aren't available in the hub 3's firewall. If you have your own WiFi router, put the hub 3 in modem mode and use the WiFi router with it. Or contact customer services and complain via the broadband faults option about the hub 3. Insist that they give you a Superhub 2 AC to replace the hub 3.0
______
Any opinions expressed by myself are entirely my own and do not represent Virgin Media in any way.
JNE
Just joined
Thanks - will give that a go
