Danrubie
Speed and connection issues
My internet keeps dropping and my speeds are low even when in the same room as the hub. Can anyone help
  • 1.34K
  • 102
  • 246
stevedh2
Knows their stuff
Re: Speed and connection issues
1st need to work out if this is an internet or wifi issue.
Do you have a stable connection wired ?
Danrubie
I don't have a wired connection other than the TiVo box.
  • 11.04K
  • 326
  • 672
Hey Danrubie,
Thanks for joining the community Smiley Very Happy
Sorry to hear about the connection problems you're experiencing. I've checked this and I can't seem to find anything out of place right now. As you're using a wireless connection, you might just need to change your wireless channel. Often this action will improve problems caused by wireless interference.
Would you have a go and let us know if this helps please.
Thanks again for posting,
Take care.
Heather_J
