skinnylove
Signal upstairs rubbis
Why carnt I get good signal upstairs and what can be done about it I have the xl package
  • 4.02K
  • 202
  • 898
cybmole
Community elder
Re: Signal upstairs rubbis
Get a bungalow.
OR
take the time to explain exactly what you are ttrying to do and with what equipment, we are not mind readers
  • 20.77K
  • 557
  • 3.22K
Sephiroth
To build on cybmole's (correct) advice, if you read other threads on this subject in the forum, you'll see two facts:
1/
Signal propagation in a house is dependent on materials, distance, objects in the way, placement of wireless router.
2/
With the exception of the latest BT Smart Hub, all routers provided by manufacturers are get you going devices with basic wireless technology, albeit to the latest standards such as AC (if that means anything to you). They all perform the same.
There are solutions to the problem of house construction/topology, which involve some modest cash outlay which we can come to when you've explained more.
