MarkDyment
SUPERHUB 3 WIFI DROP OUT
I've had a Superb 3 for a couple of weeks and the WIFI connection keeps dropping out. My iMac says wifi is connected but internet/email won't work. It's intermittent and starts working after a bit but then continues to drop out. I'm not very tech minded so no idea how to fix it. My Superb 2 worked fine before in the same position.
I've read that people had issues with the 3 last year but thought an automatic firmware update would have solved any issues now.
Has anyone got any ideas?
Many thanks
  • 12.48K
  • 353
  • 1.45K
Re: SUPERHUB 3 WIFI DROP OUT
Hi MarkDyment,
I'm sorry that you're having this issue with your Hub. There were reports last year of disconnections with the Hub 3 but that was with modem mode enabled and was subsequently fixed with a firmware update.
I'd like to direct you to a couple of our help page articles on wireless:
Optimising your Hub's wireless signal
Selecting your Hub's wireless frequency
Changing your Hub's wireless channels
 Pleas e give the information contained a try and let us know if it helps or not Smiley Happy
Jen
Latvian
Same issue here. Tried everything and nothing changed. WiFi still drops out every 30-40 min. I suspect we have global issue within Virgin superhubs and it doesn't matter which version. My superhub 3 is just month old and problems started next day it was switched on. SAD!
