Yorkshire_D
SONOS & Amazon Echo Dot issues
Hi All
Just joined Virgin Media for the first time.
Connected Amazon Echo fine and working. Tried to add Echo Dot and although it sets up okay, when you ask a question, The Echo gives you the answer, not the dot?! Very confused.
Also can't seem to set up my SONOS Play 1's.
Any help would be gratefully appreciated.
markonemode
Re: SONOS & Amazon Echo Dot issues
You will need to name the echo dot different from the Echo. For example call the Echo "Echo" and the dot "Alexa" this can be done in the app.
Can't help on the Sonos... sorry
