  • 58
Targetshooter
SH3 wifi slows from 150mbps to 33mbps in Samsung S2 tablet
Superhub 3 replaced my SH1 on Friday 3/2/17. SH1 gave me around 60mbps wifi to my samsung s2 tablet. SH3 wifi download rate falls from (110 - 200mbps) down to around 33mbps. If I then switch off wifi then reconnect the speed goes back up to 110mbps+. I understand the speeds will vary depending on time of day and network loading but why do I see adrop from > 110 to 33? Is there a setting in SH3 or my tablet causing this degradation in speed? Any help garefully received.
Speedtest on wired PC connection gives 220mbps.
  • 14.48K
  • 641
  • 1.46K
Moderator
Moderator
Re: SH3 wifi slows from 150mbps to 33mbps in Samsung S2 tablet
Hi Targetshooter,
Sorry to hear your wireless speeds are fluctuating. What have you tried so far to try and improve this? I'd suggest first of all trying changing wireless channels to see which works best in your area.
Let us know how you get on.
  • 58
Targetshooter
Hi, Thanks for suggestion. I have changed channel from 1 (Auto) to 13 (Manual). I used Wifi analyser to pick 13. There's still overlap with some other routers. I also changed a wifi setting on my tablet to always keep wifi on. Speedtest results do now look better, 85 and 90mbps. It is still the case that if I switch wifi off on my tablet for 20 seconds then reconnect then speedtest just gave me 201mbps!!.
Guess I will now stop fidding.
  • 11.04K
  • 326
  • 672
Hello Targetshooter,
Thanks for the update Smiley Very Happy
Good to hear that changing the wireless channel has helped.
Thanks for keeping us in the loop, please let us know if we can help with anything else.
Take care.
Heather_J
