HortonWho
Message 1 of 7
SH3 - wifi issues
Hi all,
I am due to have VM installed on 28/02 however i hear from 2 friends and on forums that there are major issues with wifi. Looks like it's coming from the Puma 6 chip latency problem for most people.
Is that something isolated or shall i wait and see until this gets resolved?
Last thing i want is move from talktalk and VM prove they are not reliable. I work from home and need wifi all the time.
many thanks
  • 9.36K
  • 800
  • 1.96K
Message 2 of 7
Re: SH3 - wifi issues
The Poma 6 issue has nothing to do with WiFi, however wifi connections will still be affected by incresed latency caused by the Puma 6 issue. This will only be noticed in latency critical applications like online gaming.
If you want reliability don't use wifi as it is unreliable by nature as it is affected by a myriad of external factors like Range, Wireless interference, client hardware and the Topography of your home.
HortonWho
Message 3 of 7
OK, only occasional gaming here.
should I not then be discouraged to move from talktalk?
  • 9.36K
  • 800
  • 1.96K
Message 4 of 7
it depends on what you are getting now and what you want.
I would bear in mind that there are a few congested areas with VM and it would be wise to do some research first. Have a chat with any neighbours who have VM and see what experience they are getting.
VM have a 14 day cooling off period, so you can use both services side by side (different technologies) for a week or so, so if you are not happy with VM's services you can cancel without risk.
If you do decide to switch, I wouldn't cancel your existing broadband until VM is installed as installations can get delayed, leaving you with no broadband.
HortonWho
Message 5 of 7
Hi Griffin
currently with Talktalk broadband (not fibre) and VM will take over the landline so we don't have an option to keep both for a while.
I am just after a opinion to see if VM fibre is generally an unsatisfactory service for those who use it all the time, when working from home.
  • 9.36K
  • 800
  • 1.96K
Message 6 of 7
VM use there own land lines and cables which are seperate to BT's network.
My VM service is fine,like many other peoples, but as I said there are a few bad areas so best do some research first.
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 7 of 7
What griffin said.
Unless you want to port over your number virgin you can run both services at the same time side by side as they both use different infrastructures.
