benny8ball
Message 1 of 5
SH3 and nest cam connection issues
Hello all, I cannot seem to connect my new nest cam to the Wi-Fi network. My brother in law has suggested this is because the SH3 cannot support IPV6 which the nest products require. Is this the case, and if so is there anything I can do to get up and running ? Thanks for the support!
  • 577
  • 27
  • 60
khenryashley
Rising star
Message 2 of 5
Re: SH3 and nest cam connection issues
Nest cam doesn't require the sh3 to support IPV6. The nest cam is straight forward plug and play.
Are you using the app to set it up?
https://nest.com/uk/support/article/Troubleshooting-adding-Nest-Cam-to-a-Nest-Account-or-a-Wi-Fi-net...
benny8ball
Message 3 of 5
I have tried the app on my phone and using the PC and USB connection. Both get stuck on the final stage of connection.
  • 10.82K
  • 308
  • 632
Message 4 of 5
Hi there benny8ball,
I'm sorry to read that you are having issues with connecting your Nest Cam to the wireless network.
With the Hub 3.0 it does broadcast the both networks (2.4 GHz and 5 GHz) as one. It may be worth logging into the router separating these with different names and passwords, as this will make it easier for your devices to connected too. To do this type in 192.168.0.1 into the address bar, sign in with the details underneath the router, on the left hand side under Advanced go into Wireless.
Try this and let me know how you get on
Sam
iorourke
Message 5 of 5
I've done all of the above and yet still can't get a Nestcam Outdoor to connect to my 2.4Ghz channel on my virgin wifi.
