tbp001
Just joined
SH2ac using with SH3
Hi - new on here !
Scenario :: I have a std Tivo, a TivoV6 and SH3 all in seperate rooms (3), all working fine, I have a SH2ac that I want to use in my main room where the TivoV6 is, I have a splitter etc all in place and the TivoV6 works fine, but the SH2ac is not getting a WAN ip.
Question ::  is it possible to use an 'old' SH2ac on my a/c along with the new SH3?
I have done a full reset of the SH2ac the wifi works fine, get a LAN ip from the dhcp, just no WAN ip, so just a stupid thought here - I did wonder if there was only one WAN ip per a/c as it were or do I need to have the SH2ac registered on my a/c in some way.
Have also tried going direct from internal termination to SH2ac (eliminating the splitter)
Any pointers, greatly appreciated.
  • 17.63K
  • 1.64K
  • 3.07K
Re: SH2ac using with SH3
You can only have one Hub per account, and that'll be the Hub 3.0
If you want to extend your network in to other rooms you'll need to use Powerline or WiFi extenders.
