  • 19
ade555
Message 1 of 10
SH2ac connection lost/ pocket lost
I'm trying to find the solution to this problem, my internet connection keeps dropping and getting worse, I hve been monitoring my internet over from 13 Feb to now, what could be wrong
  • 2.76K
  • 223
  • 843
Dave_cq
Trouble shooter
Message 2 of 10
Re: SH2ac connection lost/ pocket lost
Hi ade,
Crikey that is horrible!  Can you post your Upstream & Downstream data and your Network Log so that we can see your power levels please.   Type 192.168.0.1  into your browser's URL to access the hub's management but do not sign in.  Click on Router Status and you'll find the data pages there.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 72
  • 5
Thomask556
Dialled in
Message 3 of 10
if your using WiFi that's  the problem with packet loss  though post your hubs stats that way some one can have a look to see make sure to in cloud the post error
  • 9.35K
  • 798
  • 1.96K
Message 4 of 10
The TBB graph tests the latency between TBB's servers and the internet facing device of your network, i.e. the hub in router mode and has nothing to do with wireless.
  • 19
ade555
Message 5 of 10
When this was happening I phone Virgin Media and had a bit of pop because the chap was reading from a "script" and after I pointed to him few times that reseting router does not help he said he changed something at his end which should result the problem. Yes I'm using wifi but also main pc is connected with Cat6 the problem I was heaving is Full on no internet connection with green light flashing then coming back to blue and was like that on and on.
After 11am upstream
Frequency (Hz)299000000267000000275000000283000000291000000307000000315000000323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock)LockedLockedLockedLockedLockedLockedLockedLocked
Channel ID2117181920222324
Modulation256QAM256QAM256QAM256QAM256QAM256QAM256QAM256QAM
Symbol Rate (Msym/sec)6.9520006.9520006.9520006.9520006.9520006.9520006.9520006.952000
Interleave DepthI=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-1.38-1.77-1.59-1.02-1.07-1.35-1.15-1.51
RxMER (dB)38.2637.6437.3637.6438.2637.9438.2638.26
Pre RS Errors
13306066689504345972350349
Post RS Errors
278292278292304922299
305
Upstream   US-1 US-2 US-3 US-4
Channel Type2.0N/AN/A2.0
Channel ID1N/AN/A4
Frequency (Hz)46200000N/AN/A25800000
Ranging StatusSuccessN/AN/ASuccess
Modulation64QAMN/AN/A64QAM
Symbol Rate (Sym/sec)5120000N/AN/A5120000
Mini-Slot Size4N/AN/A4
Power Level (dBmV)45.25N/AN/A44.25
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts1000
T4 Timeouts0000
After 11am you can see the change
  • 19
ade555
Message 6 of 10
Anyone can help with this?
  • 10.02K
  • 332
  • 877
Hero
Message 7 of 10
Line noise of a bad cable or faulty Amp
  • 19
ade555
Message 8 of 10
So what can I do about it? or I need to speak to Virgin to get someone out as is getting worse again
Downstream   DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV)-1.89-2.31-2.12-1.54-1.62-1.77-1.73-2.06
RxMER (dB)37.9437.3637.0937.3637.9437.9437.9437.94
Pre RS Errors
58203094724881363364994366370
Post RS Errors
278292278292304922299305
Channel ID1N/AN/A4
T1 Timeouts0000
T2 Timeouts0000
T3 Timeouts1000
T4 Timeouts0000
  • 72
  • 5
Thomask556
Dialled in
Message 9 of 10
you will need vm to sort things out one of them will pick this post up in a few days though i would give them a call or use the live chat service. its open today
  • 3.88K
  • 121
  • 203
Forum Team (Retired) Adam_L
Message 10 of 10
Hi ade555,
Thanks for letting us know about your internet dropping and losing connection, I apologise for any inconvenience caused.
I have tested your connection from here and I noticed a large number of T3 time outs inside the Hubs logs and an engineer will need to attend and investigate this further for you.
I will send you a PM (purple envelope at the top) detailing what's required to proceed with making the booking. Please respond to me there and I'll get this sorted for you.
I look forward to your reply,
Adam.
