Sjknox1
Router loud buzzing noise
My router seems to have a loud buzzing noise every so often. Checked connections and seems to be ok.
Read other posts and looks like replacement needed?
  • 3.01K
  • 383
  • 952
Re: Router loud buzzing noise
It is worth checking that it is definitely the hub making the noise and not the power supply.   The quickest way to get faulty kit replaced is to call them on 150 (from a VM phone) or 0345 454 1111 and report the fault, otherwise you are looking at a 7-10 day wait for a staff response on here at the moment.
______________________
Scott
Sjknox1
Thanks. It is the connector I think. The silver rectangular bit
  • 10.62K
  • 311
  • 654
Hey there Sjknow1,
Thanks for posting and welcome to the forum Smiley Happy
Sorry to hear about your noisy equipment!
Let's get this replaced for you. I'll drop you a PM (purple envelope, top right) to confirm your address.
Speak with you soon,
Take care.
Heather_J
